Audi A5 / S5 / RS5 Coupe & Cabrio (B9) Discussion forum for the B9 Audi A5, S5 and RS5 Coupe and Cabriolet 2018 model year and up
S5 oil change?
Old 09-04-2017, 01:13 PM
  #21
uberwgn's Avatar
I would always double-check the under-hood label for the oil spec. The newest cars get a new 0W20 oil meeting VAG spec 508.00/509.00. You're not going to find this oil at the corner store.
Old 09-04-2017, 02:48 PM
  #22
synergize's Avatar
Received 1,254 Likes on 774 Posts
Yep, the dealers have it for about $8.75 per quart.
Old 09-04-2017, 03:30 PM
  #23
AUDIQSS's Avatar
My B9 S5 does NOT have a dip stick, NOR does it have a dip stick hole. So if yours does please tell me why mine doesn't and how I can use an oil extractor using that non-exsistent hole.
Originally Posted by HudsonS5
Audi doesn't include an actual dipstick anymore, you have to use the MMI to look at the oil level. Hopefully ECS will sell a dipstick for it soon. But there is a dipstick tube by the oil filter, at least I'm pretty sure it's that based on previous recent VW/Audi's.
Thank you Sir for this information and the pictures. I found it! I stand corrected. However, I won't have to use this information for about four years as I got my dealer to include Audi Care as part of the deal. Four years from now is another matter. Thanks Again!!
I will now check with the service department to see if there is dip stick/"tool" available to double check the oil level.
Last edited by AUDIQSS; 09-04-2017 at 03:33 PM. Reason: add my original wrong statement
Old 03-10-2018, 01:02 PM
  #24
Waggin's Avatar
It looks pretty easy to extract the oil through the dipstick port, you don't have to get under the car.
I'm not sure how different the S5's 3.0T engine is.
The first time I did it this way, I'd also pull the drain plug to see if it missed anything.
Or, before buying, drop a long rod into the hole until it stops, then measure the height of the top end. Pull it out, hold over garage floor at same height and see how close to the floor the bottom end is. If it's the same height as the oil pan bottom, then it's ok, If higher, then it won't drain it all.
daczone
12-31-2016 11:05 AM
Prime Time
A4 (B8 Platform) Discussion
12
01-11-2015 10:04 PM
MDIRADS
13
02-12-2006 09:03 PM
odonnks
03-22-2003 08:14 AM
S62NV
Audi Original "S" Cars
09-10-2002 09:54 PM
Quick Reply: S5 oil change?
