Audi A5 / S5 / RS5 Coupe & Cabrio (B9) Discussion forum for the B9 Audi A5, S5 and RS5 Coupe and Cabriolet 2018 model year and up
S5 SB - 2,200 miles - Now with Check Engine Light
Old 01-29-2018, 05:27 PM
Ventanaman's Avatar
Default S5 SB - 2,200 miles - Now with Check Engine Light
Just got the yellow check engine light on my new 2018 S5 SB. No obvious issues - anyone have any idea, or is this a known issue.
Nearest dealer is 60 miles away. Grrrrrr.
-VM
Old 01-29-2018, 06:11 PM
N8!
N8!'s Avatar
might be this:
https://www.audiworld.com/forums/aud...-mode-2935082/
The problem seems to be only with S5's thus far....
Old 01-29-2018, 06:28 PM
Ventanaman's Avatar
Originally Posted by N8!
might be this:
Thanks - it is running fine, definitely not limping.
I re-tightened the gas cap and see if it goes off in a couple of days.
Thanks.
-VM
Old 01-29-2018, 06:41 PM
N8!
N8!'s Avatar
If it's the gas cap it should clear as soon as you restart the car.
Old 01-30-2018, 02:55 AM
machz's Avatar
Not always, my jeep and my mini both had evap lights from the gas cap and it took 10-15 miles before it shut off.
Old 01-30-2018, 03:26 AM
heisnuts's Avatar
With a check engine light you really need to know what error codes are in the system to determine what kind of problem you have. The fact that it did not go into limp mode and that the car otherwise seems to be running ok tells me it is probably not something major. If it is an evap code due to a loose gas cap it might take several days for the car to go through the required drive cycles to reset the light. When you checked the gas cap, did it seem to be tight already? If so, you will probably find that the gas cap was not the problem, but again, the error codes will tell you a lot more.
Old 01-30-2018, 08:46 AM
freshpow78's Avatar
Wife's 2017 Q7 CEL (in fact, the whole dash basically lit up like a christmas tree) came on at about 4,000 miles. Took it in, they applied a software update and it was fixed. Dealership told me that I was a few updates behind. Sooooooo..... 8 different warnings are going to pop up on my dash even though nothing is technically wrong... and possibly because I'm a "few" software updates behind? Wow..
I've heard of these issues with several newer model cars of different brands. All of this technological dependence in new cars is a bit scary to be honest, especially when you consider that auto manufacturers are NOT software companies!
Old 01-30-2018, 08:49 AM
ArvX147's Avatar
Just keep driving unless there is something apparent wrong with the car.
Old 01-30-2018, 01:25 PM
Ventanaman's Avatar
Good news. Tightened the gas cap last night and the CEL was off this morning. Obviously, will keep an eye on it.
Thanks everyone for the help.
-VM
Old 01-30-2018, 05:08 PM
superswiss's Avatar
Received 1,069 Likes on 743 Posts
It's a good idea to get something like Carista or OBD11 so you can read the codes if you get a CEL. The CEL can come on for things as simple as bad fuel causing misfires. Often these things clear on their own and the CEL goes out a few days later or even sooner like in your case. It does sound like it was the gas cap in your case. Also, in general a solid CEL is not a major issue, however if it's flashing than you need to have it checked out ASAP.
Quick Reply: S5 SB - 2,200 miles - Now with Check Engine Light
