S5 Tire replacement
Car should be in within a few weeks. There is a good chance I just change the summer tires to AS. In addition to the Pilot A/S3+, what other all seasons do people like? I think I say Continental mentioned but couldn't find it.
The system is using the VSA/ABS sensors to determine if the tire is low by calculating the wheel rotations are different than the set amount. That is why when the tires/pressures are changed by the owner the TPMS system needs to be updated to the current tire pressures. That can be done in the vehicle settings in the MMI. The advantage is that you do not have the added expense of TPMS sensors, but the disadvantage is that you do not have a display that shows the current tire pressure of each tire.
snagitseven
A4 (B8 Platform) Discussion
13
09-23-2008 12:45 PM
///Mike@Boston Audi
Chicago Discussion
05-29-2006 08:48 AM
Evan (Vogon)
10-11-2001 03:53 AM
