Sportback hatch trim removal
I can't seem to figure out how to remove the hatch trim on my A5 Sportback, and I hate seeing the adhesive clips I've had to use for the cable going to my rear dashcam. Would anyone happen to have instructions/tips?
BTW. If you're installing a Blackvue with thinner cables, then you may be able to install the rear dashcam by just prying open the top panel at the top of the rear window. I had to take off the entire top panel to make the mods to install the Viofo due to the way the cable plugs into the rear cam; you have to mod the top panel one way or another or position the cam lower on the window which is not desirable. Attaching the Viofo rear cam the way I did was, IMO, the best setup I could figure out.
Seanism (clone510)
08-01-2003 10:10 PM
