Wireless Carplay
#331
So i hooked VCS up to the car today and i have the 2019 with the phone kit. I have the module 75, but it only had 5ghz listed, nothing in the adaptations listed car play and i didnt have most of the adaptations listed in 5f either. Granted my MMI hasn't been updated since i got the car and i am on an older build of VCS from early 2019, but not sure that would make a difference.
#332
yes suspect there will be differences .
If you are able to enable 5Ghz in module 75,
you could try the following values in Module : 5F. (Information Control Unit)
Adaptation
Vehicle Configuration
MirrorLink = On
WiFi_Client_HMI = On
Apple_DIO_Wireless = On
wlan_5ghz_switch = Activated
Apple_DIO = On
Adaptation
MirrorLink = On
Apple_DIO = On
#333
Adaptation
MirrorLink = On
Apple_DIO = On
Adaptation
MirrorLink = On
Apple_DIO = On
#334
Club AutoUnion
I, for one, will take the “trade-off” of no touch screen & a volume control for no (factory) wireless CarPlay.
— John
— John
#336
Same, except using VCDS. I also unpaired my phone from Bluetooth and Carplay prior to changing the above. And afterwards, I reset the MMI. But, there was no change in the name of my Wifi network (apparently it would've been appended with "_5ghz"). I found the OBD Eleven CarPlay Thread over on the OBD Eleven forums that the above steps were copied/pasted. Note that everyone posting there seems to reference the MIB3 (touchscreen) MMI found on the 2020 USA cars and 2019 non-USA cars. Just different hardware, maybe a dead end for us with MIB2.....
#337
Permanent S Mode Member
After playing around with this for about 3 hours (car battery on trickle charger) and having done everything you did and changed the S5's wifi password and then connected to the my iPhone X, I am able to connect to the cars wifi easily, but no Carplay. I'm gonna let it sit for a few hours and see if it Carplay appears in the MMI. Sometimes it can take a few minutes to a few hours for changes to occur. After that I am finished and will connect via the cable (that is not such a big deal anyway). I want to keep my hair (I almost pulled it out this morning)...I know when I am beaten and Wireless Carplay can go F#@#% itself right in the lightning connector!!
#339
it’s difficult without seeing it. If you want to backup module 5f and 75 I’d be happy to take a look.
It maybe that it’s not possible but worth a go I suppose.
#340
No 5G label on my Car's Wifi. I'll double check it and make sure, do you have 5G in your car?
