"supafly" custom roof rack: $6 plus labor
Tip for you thrifty allroad owners:
I made a couple roof racks for the allroad a while back, and finally got around to posting pix. Took a 10-foot piece of 1 1/2" PVC pipe, four 90 degree elbows and some duct tape, and they should be able to handle up to 100 pounds or so (evenly distributed).
<img SRC="http://www.mnaudi.com/mymnaudi/images/837/RoofRackSide.jpg">
The only fabricating needed was to cut some slots in the bottom of the racks to keep them upright when bungeed down. Pretty self-explanatory I think.
The duct tape serves two purposes... 1) keeps the rack from scratching the rails on the car and/or the load I'm carrying, and 2) gives the racks that "ghetto-OEM" look.
Held in place by bungee straps. All told I put about six bucks into them -- they're 4 feet wide and the sides keep the load from wandering off in corners. Obviously if I was hauling sheetrock or something similar I'd need to unscrew the antenna, but that's simple enough to do.
<img src="http://www.mnaudi.com/mymnaudi/images/837/RoofRackBack.jpg">
I kinda like how they make the car look like it's sporting devil horns
Next improvement, to make them collapsible so I can keep them in back w/o taking up the entire cargo area.
EDIT: These are for those "emergency times" that I haul crap that won't fit in the car, thought some others may want to do the same w/o buying the spendy OEM or thule, etc. bars, which are less useful than these bars for long loads (such as sheetrock or a couple 2x4's) as they need to attach in the "factory spots" -- right up front and then 2/3 of the way back on the rails. So don't be hatin' -- I'm just offering a cheap alternative. Jeez. ;-)
![Stick Out Tongue](https://www.audiworld.com/forums/images/smilies/tongue.gif)
Now your pipes are open and in rain water can go into tubes. So I suggest you add tap to both pipes to drain them!
Who can be more clever than human? Engineer
Who can be more clever than engineer? German engineer!
Tape actually covers the holes at top except for the spots where the bungees go -- and I can always just tip 'em upside down. Haven't used them in rain yet -- so I may need to add taps yet! Thanks for the suggestion.
...from Home Depot or Lowe's. Other than that right now, I have no need for a roof rack system.
