19x9.5 ET 33
Hello everyone, hope all is well. I need some suggestions on tires for the 19x9.5 ET33 for my 2017 B9 Allroad. Some suggested to get a 255/40/19 some said a 275/35/19 or 235/35 19 All I need are tire size specs that will look square and not look stretched and not sacrifice too much of the speedometer reading. Appreciate some suggestions. Thanks.
I presume this forum is more for the turn of the century C5 A6 allroad, which was simply called "allroad" back then. The B9 A4 allroad has its own forum, https://www.audiworld.com/forums/a4-...iscussion-216/
et33 is right at the stock et32, so how much wider a tire do you think you need to make it look however you want it to look? Stock is a 245/40r19 tire on a 8.0 wheel. So probably something like a 9.8" section width. 26.7" diameter.
275/35r19 would be 26.6" diameter, and 11.0" section width on a 9.5" wheel. So a half inch more outward and inward vs stock tire width. "look ..." is likely a subjective assessment and gong to vary from tire make to tire make.
Thanks for the link and sorry about the wrong forum I posted my inquiry. Thanks as well for.your input.
Chipmonstr (06-20-2023)
Avantissimo_06
10-15-2004 02:17 PM
