2001 Allroad transmission issue!
I have an 01 Allroad 2.7T and the transmission is acting up, the tranny does a hard downshift into 2nd gear all the time. Seems like it got worse to doing it every time now and seems harder downshift when braking. The rpms jump up a notch then back down a notch when going up a hill or sometimes level road. I have not changed the filter or transmission oil yet but plan to soon, should this be a serious concern? Or is the torque converter possibly going?
Yikes ! Has it thrown any codes yet ? CEL or anything? If its a 2001 and never had a torque converter (Unlikely it would have made it this far) i would be concerned. I just had some reverse chatter issues and did the fluid and filter ---made a huge difference and problem went away. Sadly yours sounds serious.....
The way a transmission works, the converter has nothing to do with shift quality in any way. If its banging into second on decel that could be a sign of low fluid or badly worn fluid, or damage inside the trans. At this point try servicing the transmission, if it doesnt helps, its junk. This is why you service transmissions every 50k or so and not wait 100 some thousand miles and start having problems to suddenly do preventative maintenance.
If you've never done this before, and are hoping to do it based on a technical book, i doubt you will be able to do it, or that the rebuild will last.
MrMoneyPenny
01-07-2013 07:56 PM
pdacosta
10
01-31-2007 08:08 PM
