2002 Allroad - wiring of oil temp level sensor - where is 10 pin connector T10o
Trying to trace the oil temp level sensor wires.
From sensor, it goes to
T10o (ping 8 and 9), connector 10 pin, brown, connector station electronic box plenum chamber
Where is the 'electronic box' in 'plenum chamber' (where is plenum chamber)?
Bentley computer broke down, can't access.
Wires have continuity, ground good (extra ground run just to be sure).
VAGcom shows oil temp (in instrument module).
VAGcom output test for instrument cluster shows oil temp gauge 'moving ok'.
Yet oil gauge is NOT showing temp.
Any tips what to do next?
I would expect a bad sensor (new, Meyle (a lot say the Meyle sensor fails early, but this never worked after install) would NOT provide VAGcom with an oil temp reading?
dspang
06-15-2009 02:42 PM
AudiSportB5S4
07-06-2008 07:08 PM
