2003 Audi Allroad 2.7 Coolant leak (expansion bootle?)
#11
i also get a burning oil smell and sometimes smoke, especially after not running the engine for some time, i belive i was reading about that and it is pretty known issue for those engines to leak from valve cover?
#12
Correct, the valve covers can and certainly will leak the gaskets were not replaced at some point in their lifetime... I did mine at about 150K miles, yes, they were leaking down causing the burnt oil smell thang that is so common with these 2.7TTs motors.
#13
I was in rush no tine to get it, i used a gallon of poland spring and some g13 ima flush the system upcoming weekend and fill it up with new coolant and distilled water.
Also could somebody give me right part # for that Aux Water pump? i see two different models and im confused.
....earlier "APB" motors (2002) used # 078 965 561.
#14
If you are replacing the aux pump, you are going to need some other parts as well. If you are going to the trouble of getting in there, you might as well replace the hoses and the mounting.
Assuming you have the US (cold climate) edition 2003 onwards you will need:
3D0-965-561-D Additional Water Pump
035-959-209-F Additional Water Pump Mount (2 off)
078-121-082-E Water pipe to additional water pump (Straight)
078-121-082-H Water pipe to additional water pump (Angled)
078-129-717-N Intake Manifold Gasket (2 off)
Plus a variety of hose clamps because you have to cut off the clamped ones.
If you have the Hot climate model ( ie Australia and asia) you change the 2 water pipes above for:
078-122-349-A CHECK VALV
078-121-082-M Hose
The check valve come complete with the hose connections already attached. Don't buy it if you have the cold climate edition, it costs as much as the aux pump.
John
078-121-082-M Hose
John
#15
Just so.im sure pump is a black part horizzontally right by the enging (right side of the engine if u standing right on front.) Right under the intake manifold? I can see water around there. If yes, are the part numbers correct? (Given by the other member of the forum on this thread) I need to ordet these parts i need my car running. Also part numbers for the valve cover gaskets and the camshaft gaskets please.
Thanks guys, u r really helpful.
#16
Here's a picture of when I did mine a few months ago. It is the black part in the center of the picture with all of the coolant that had leaked underneath of it. The picture is taken while standing on the driver's side of the engine with the valve cover taken off.
![Name: IMG_20130810_113035_zpscf8b109b.jpg
Size: 94.0 KB](https://www.audiworld.com/forums/attachments/audi-allroad-18/83885d1501531836-2003-audi-allroad-2-7-coolant-leak-expansion-bootle-img_20130810_113035_zpscf8b109b.jpg)
Here it is if you were standing at the front of the car looking back.
![Name: IMG_20130810_113006_zps40dd7b7e.jpg
Size: 105.0 KB](https://www.audiworld.com/forums/attachments/audi-allroad-18/83886d1501531836-2003-audi-allroad-2-7-coolant-leak-expansion-bootle-img_20130810_113006_zps40dd7b7e.jpg)
#18
#20
Juno,
Looking at the first photo provided by GOto60 you can see all the cooked coolant under the water pump and where it leaked out the front of the pump around the hose. Part numbers are
water pipe with the bend is: 078-121-082-M
Bosch pump is: 3D0-965-561-D
black rubber rings are the pump mounts: 035-959-209-F (2 off)
pipe-check valve- pipe (all one unit) 078-122-349-A
you also need two inlet manifold gaskets 078-129-717-N
other than that you need some hose clamps as the Audi ones on the vacuum and other lines are the crimp type so you need to replace the ones you cut off.
