2004 Allroad
We bought a 2004 Allroad a few months ago and love how the car drives. But now we have a issue with the oil light coming on when we slowed down coming off the highway. Did this several times last night. now this morning we went to drive it and got a few miles down the road and the light came on and stayed on this time. So I had it towed home. Now after doing what I could do for research it seams I should start with the oil pressure sensor. But I cant locate it on the engine. If some one could point that one out it would be great. If that does not work it looks like my next step would be to drop the oil pan and clean it and the intake. Any suggestions if I should try some thing different? Could it be the oil level sensor on the pan. The car is good on oil and we never heard any knocking as if it was starving for oil.
Thanks
Shade Bush Mechanic. ( I don't qualify as a shade tree one)
Thanks
Banned
as long as the trusty dip stick shows a crankcase filled to the proper level, dont worry about the sensor until your next oil change
dont wanna change it while full.
you can look up and see the rectangular plastic sensor inserted up into the pan.
Try the suggestion above about cleaning off the connector contacts. you can do that without removing the whole sensor. You don't want to pull the whole sensor out when there is oil in the pan.
If that doesn't fix it, get a replacement sensor ready for your next oil change. After you drain the oil, simply swap in the new sensor and reconnect, and then when you complete the oil change and start driving around, you can see if that solved the problem.
gruvenparts.com
10-11-2016 04:47 AM
joshA4
10-11-2015 02:43 AM
bertrenolds
Audi allroad
09-30-2015 06:08 PM
Audi A6 2003 allroad 2.7t for sale in AZ
blackjulia
09-27-2015 09:37 AM
