2005 Audi allroad running lean/horrible gas mileage
So Maybe you guys can help me here but I have a 2005 Audi allroad 2.7t which has an engine code p2096 -which says its running lean. I’ve replaced the air filter,spark plugs,O2 sensors,fuel filter,cleaned the MAF sensor but it’s still throwing the code! Any ideas!? Vacuum leak? Fuel regulator sensor?Also it’s really affecting my fuel mileage, car runs great either then that. Thanks
I would think you are on the right path. If the DTC says it is running lean but you are actually running rich (increased gas usage) then I would also suspect something wrong with fuel pressure or fuel injectors.
Also might want to just replace the MAF too instead of just cleaning it. Or buy one see if it makes any difference and if not return it.
Or you could try just unplugging the MAF then the ECU should go into closed loop operation where it won't use the MAF signal any more in case the MAF is sending bad information.
O ok ya my fuel mileage is absolutely horrible right now,my lifted Jeep gets better mileage..extremely frustrating..
ya I’ll look into replacing the fuel pressure regulator ,clean the injectors again and play around with the MAF again.
technics100
1.8T Discussion
07-12-2006 05:53 PM
WhiTTeRainbow
01-21-2005 07:26 AM
