402 anyone help ???
I know you suppose to measure 402mm from the center of the wheel to the fender on level 2, but the measurement will not be acurate cause it will be on an angle (at least with my 225 tires which are not aligned with the fender) ???
When doing adaptation and inputing values for lowering example 415mm on 01,02 so on levels, when you go to save it shows you 402 value on the popup, not the one you input in the window for selected wheel ??? Is that the way it works ? Shouldn't it ask me to save value of 415 ? not 402 ? for example ?
I measured twice the distance between the fender and the wheel (on an angle) on level 2, (after several trials of going from 1 to 2 to 3). Once it showes me being 370mm both sides in the rear, other time LeftRear 371mm, RightRear 381 ?? How can it be ??
Last but not least when it says in the guide as 01 being Left Front and 02 Right Front, from which perspective is that, drivers ? or from outside facing the car in the front ?
Thanks for help !!
Thanks for help !!
We used this as a point of reference and went in increments of 5 when doing the adjustment. So, adjust values by 5, cycle thru all levels, measure, adjust again, etc. We also noticed that my right rear was 1 cm higher than the other 3 wheel before we did the adjustments and accounted for that in our calculations.
I have 2004 allroad and I do exactly as per instructions, but when I try raise it by entering 395 value for example it seems that it goes down even more ??? What am I doing wrong ?
How did you do it ? When you went 5mm up, than you entered 407 in all corners correct ? when you went to save you were actualy saving 402 (that is the popup save screen). After the adaptation finishes you enter 01 value for 05 height and you save, you get error and you are done ?
what you are doing with this mod is telling it that HOME is 'off' by 18 mm or whatever your input is. Once you save it and go back to check it..the system thinks the new position is HOME or '402'.
