402 mod, 15mmF/12mmR car not quite sitting level...what do you think I should do...
the butt is a little lower than the front, not all that much but it's not sitting level. So should I lower the front a few mm or raise the rear a few mm? I'm inclined to lower the front in that I don't the back looks "too low"
your eye but write down data for all 4 corners. You could end up in a bit of a mess if you are not careful!
Ideally it is a good idea to measure things before you mod.
Go up to level 4 car empty then bring it back down to level 2. Now measure, I use floor to lip edge of fender.
402 mm is the center of the wheel to fender edge but that is no accurate enough so just use the floor. Make sure your tires are equal pressure.
Good Luck
Good Luck
