402 MOD, getting Login errors; "login lost due to dropped session"
communication is good across the board but it won't login for adaptaion. anyone ever have this with the VAG software??
thanks!
thanks!
and processing speed to run correctly...i.e. it will load but will give time out and other errors if there is too much running on the machine (shut everything down, take photos off desk top etc)...also folks have a tendency to load this software on older laptops as they will be going to the garage and that causes issues as well. Good luck.
If you have a bad sensor it will give you "login lost due to dropped session" error as soon as you try and to the adaptation.
The thing is the bad sensor error showed up a little later. But once I replaced the level sensor the "login lost due to dropped session" problem disappeared for good.
