6 speed question
Old 10-04-2004, 07:49 AM
New Member
dvdkey's Avatar
Default 6 speed question
2001 allroad 2.7T 6 speed. when trying to really punch it in second gear after completely letting up on the clutch, the engine will rev really high for a couple of seconds almost as if I am hitting the gas with the clutch in, but then winds down a little bit and feels like it is engaging for a second time before it really takes off. Is this just the turbo kicking in?
Old 10-04-2004, 07:55 AM
New Member
mark_avant's Avatar
Your clutch is slipping (probably worn out)
ShowMeData's Avatar
Default Sounds like clutch slipping.
Watch the tach. If the RPMs are jumping, it's the clutch. If not and it's just aural, then maybe it's engine sounds you're not used to.
Old 10-04-2004, 07:56 AM
ShowMeData's Avatar
Dang - beat me by 16 seconds!
Old 10-04-2004, 08:01 AM
paulroad's Avatar
Default Had this since week three of the ar..
Under extreme hard excell.. if I din;t let 2 or three bite 100% then it would slip.... The clutch or pressure plate.
Fortunatly..if you are under 50K miles.. its all warranty.
Old 10-04-2004, 08:05 AM
happy allroader's Avatar
Default Sounds more like a clutch about to go. Slipping on a worn out clutch?
Manual transmissions are a direct connection in that engine rpm and wheel speed are directly proportional. The "winds down" is the clutch finally engaging. I'm a tip man myself, but in my old Triumph TR-6 the clutch friction material was riveted (some use a bonding material) on to the clutch plate (disk?). If you start to feel the clutch slip it was sliding on the rivets. If you didn't fix it quickly, it would scar up the pressure plate and/or flywheel. Just for info, normally you replace the throw out bearing when you do the clutch. Some forum members have done their clutch so you may want to search and see if this is a do it yourself project.
I did a quick search and URL is a good thing to help diagnose your problem.<ul><li><a href="https://forums.audiworld.com/allroad/msgs/84800.phtml">https://forums.audiworld.com/allroad/msgs/84800.phtml</a</li></ul>
Old 10-04-2004, 08:13 AM
xtreetoes's Avatar
Default Re: Dang - beat me by 16 seconds!
Put the tranny in 6th gear at a stop and let the clutch out. You will know right away if the clutch is slipping :-)
Old 10-04-2004, 09:08 AM
paulroad's Avatar
Default Funny you should ask this... E-bay... buy it now $283.00
A complete kit listed right now. Made by the OEM manufacturere SACHS of Germany.<ul><li><a href="http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&amp;category=33730&amp;item =7925154332&amp;rd=1">clutch</a></li></ul>
Old 10-04-2004, 09:48 AM
New Member
dvdkey's Avatar
Default Re: Had this since week three of the ar..
thanks...i'll have it checked out.
Old 10-04-2004, 10:19 AM
meallroad's Avatar
Default Definitely sounds like a bad clutch...confirm this by putting on the e-brake,
then put it in 1st and let the clutch out. If it immediately stalls the clutch is good if it doesn't the clutch is bad.
Quick Reply: 6 speed question
