65535 ??? suspension...
Suspension panel( up, down buttons) is flashing and susp. light is on.
Control modul makes noise(click,click,click) all the time...
Compresor is not working...
Anyone had that noise(click, click, click) when control modul needed replecament....
Vag says:
65535 - Internal memory error 00 - 00
Help...
Vag says:
Help...
A little help as well...
Seems like it was the weekend for air suspensions to unit and crap out...
Mine also is acting strangely where as it was adjusting at a stop light, the warning light came on. After leaving it parked at my destination for 3 hours, I noticed that the rear did not look inflated. I put it into jack mode and then cleared it and the light remained on and the back still seemed uninflated. I drove home and when I got there, the rear re-inflated up to look consistent with Level 2 but the warning light remains on without any lights on the suspension buttons.
I looked for fault codes last night with the VAG but am not seeing any. Any suggestions besides "take it to the dealer"?
Of note, I had a flower arrangement in the back seat that tipped over and a couple cups of water spilled onto the rear mats with some of it seeping through...I did notice that the chassis has a drainage point as the water dripped under the car!
jack mode not working. Suspension panel is flashing, and there is no response from the
UP and DOWN buttons. Looks like whole sysytem is dead. I try to calibrated ( 402 mod) but no joy, won't read neither of the channels ( 01 -> 04). I'm going to bay new one today.
The one I have on the car supposed to be fix but it's still same problem: NOT WORKING...
PS.
I try the meas blocks as well so the all whell sensor are working( jack the car up, and they read all height changes). Disconnect compresor and everything under the car(all plugs there) and Vag catch new errors, so it,s seems that those compoents are OK.
PS.
AudiWorld Uber User
I have a used, but perfectly fine controller I'd be willing to sell cheap.
Re: is your compresor works at the time of this?
I believe the compressor was working but that was while the lights were still working as well. Weirdly, after it re-inflated the air bags to the normal height is when all went dark. I haven't driven it for a couple of days now hoping that time alone may help it.
I plan on pulling the fuse and then putting it back and see if that resets it. I just have to check which fuse to pull.
Update...It's alive!
Thanks for making it easy. :P
Well, looks like I may be one of the lucky ones (for now). The controls are back operational and the compressor is still pumping! Took her up to Level 3 and will let it sit there overnight.
The yang to this ying is that my wife managed to rip the top off the power mirror switch - she doesn't know her own power - which unfortunately is supposed to be a one piece design. At least replacing that will be much cheaper than the air suspension.
