adjusting side mirror dip in reverse
Old 04-15-2005, 06:46 AM
New Member
smackboy1's Avatar
Default adjusting side mirror dip in reverse
how do you adjust the preset angle the passenger side mirror dips when in reverse? the manual doesn't say and i seem to remember being able to adjust it, but then again i maybe confusing the allroad with my wife's e430
Old 04-15-2005, 08:29 AM
gragravar's Avatar
Default you can stop it from dipping by moving the mirror control ****
back to the center position, but I don't remember a way to adjust how far it moves.
Old 04-15-2005, 08:37 AM
New Member
smackboy1's Avatar
Default it dips too much
right now the side mirror dips too much, I can't see squat, so i end up defeating it. i swear i remember being able to set the preset dip angle, but then again, my memory isn't a lucid as it once was.
Old 04-15-2005, 10:19 AM
New Member
tonester's Avatar
Default let me know when you find out!!
I too disable it because it's too deep - very annoying when a product is over-engineered.
Old 04-15-2005, 10:20 AM
tung-sol's Avatar
Default use the third memory setting ...
I set both mirrors just right and stored in Memory 3, leaving the seats, etc., and use it just for backing out of my driveway and parking.
Now, if you have 3 drivers, that's another story
Old 04-15-2005, 10:30 AM
Dr.quattro's Avatar
Default I think you do it with the keys in the start position (car not running)
then you turn the mirror *** to the passenger mirror setting, then adjust. Then turn the *** to the "neutral" setting and turn the power off. It should be set....oh yes, do all this with the car in reverse.
Old 04-15-2005, 11:22 AM
New Member
smackboy1's Avatar
Default nope, that ain't it
ran out to the car and tried it.
Senior Member
allroad'Ed now's Avatar
Learn something every day on this Forum. Didn't know it COULD be adjusted.
Old 04-15-2005, 01:27 PM
rdar's Avatar
Re: Could not find a way either. Funny the Passat has this feature.
Old 04-15-2005, 01:48 PM
Dr.quattro's Avatar
Default did you do it with the car in reverse?
I thought that was the way to adjust it. It is adjustable, if this method doesn't work, we will find out for you.
Quick Reply: adjusting side mirror dip in reverse
