air suspension valve block problems
#12
I have 2003 AR and my suspension works most of the time. I am an air compressor mechanic, but this compressor is diffrent. some lubrication may help. I was not aware of a inlet filter i will look for it now. My compressor does sound a little rough sometimes and i will get thre lights in the dash light up. I think it means it has overheated. i may try the oil
#14
Just an air-tool lubricant, just like you'd use in a nail-gun or rattle-gun etc. I originally oiled my system because the distribution valve block was 'sticky' and causing all manner of faults. It's been all but faultless since.
When I say 'all but'... The other day I was parked on an odd angle in a snow bank... when I came back from skiing the suspension was right down. It came up fine (and never sags when parked normally). First sign of a bag leak? Or did a valve cause it to dump it's load?
Blackshasta, can you enlighten us as to what's different about this compressor?
#15
#17
the three lights are in the speedometer ABS, a car with upand down arrows ,and a traction control light?? i beleve.
this ari compressor is very diffrent in the way you cannot replace individual parts to in you have to replace the whole shebang.. i still havent tried the oil but will tonight....thanks for all the help. will post results
#19
hi chris here in the uk just bought my frist allroad today the car was not raising at all and the dash light was flashing all the time i removed the air filter and sprayed wd 40 down the tube then sat in the car and played with control and whent for a dive the car works fine now up down great the pump sounds alittle loud tho could be pump on way out thanks for tip great
