Air suspension work while engine is switched off?
Hi all, I bought an Audi allroad 4.2 at the auctions only to find out when it got delivered the car is a non starter.
Is it possible to raise the car on its air suspension when the engine is not running? as its currently on its bump stops.
I've tried searching for this simple question but to no avail.
https://snaptube.cam/
Thanks in advance.
Thanks in advance.
Yes, the Allroad is always running the air suspension. When it is down like you mention, it is typically due to a leak somewhere or the pump is not working. The later could be a relay or the pump itself.
The best way to debug this part is with a VagCom. There are more information to be found on this and other sites about getting it fixed.
Sportastic
A6 (C7 Platform) Discussion
09-21-2020 04:49 AM
