Airbags - change spring rate
#11
Hackers to the rescue!!
I am sure there is quite a bit of potential in our suspension system still to be uncovered.
Next time on the hoist, I will also check if there is a mechanical way to preload the airbags (higher pressure, stiffer spring rate).
Does someone have contacts at Arnott/Bilstein to find out more about the spring rate of the stock/Gen 1/Gen 2 bags, and the dampening rates of the stock vs. Bilstein shocks?
How about a supplier coming up with electromagnetic shocks for the Allroad?
#12
Just thinking here:
I would like to make the air bag springs stiffer.
Increase the pressure inside the bag does not work (changes the ride hight). Unless the air bag is 'pre loaded' with some extra force (think rubber bands).
If changing the pressure is not practical: how about changing the compressible volume of air inside the bags?
I am thinking to put some non foaming (so the liquid does not get into the air supply/return line on top of the air bag) liquid into the bags, effectively reducing the volume.
The adaptation only controls height. So if you want to lower/lift the car then use Adaptation. If you want a different ride (spring rate) use soft coding.
Try 24400, 23300 and see what happens. This may raise/lower the car though, but it seems to also change damping. One could maybe try the soft coding in addition to Adaptation to bring the height back in line.
This tricky PDC valve may actually do more than Arnott is telling us when getting the Bilstein shocks, which do NOT have it !!!!
NOT SO, apparently. It changes the dampening of the SHOCK depending on air bag pressure. This may explain why the car feels under dampened when lowered (402, for example in my case -20mm): the corresponding air bag pressure for the low height results in lower dampening of the air bag, and a 'bouncy' ride.
The reduced volume would NOT change the static pressure in the bag (determined by the piston area and the static weight/load; and the chosen height).
The higher pressure in the bag (for the same amount of wheel travel) should automatically cause the PDC to dial in more dampening.
I don't think the pressure changes all that much from one level to another. The air volume does change some, and the amount of air changes, but the pressure to support a given corner weight of the car is closer to constant than widely variable. So the PDC valve shouldn't be changing the damping all that much from one level to another. It is after all only designed to change the damping for increased loads, which will increase the static pressure for a given ride height.
I would love to have active damping shocks on the allroad! I've thought about looking into it, but unsure if any manufacturers work in low volume, and then it would probably be very expensive.
#13
JustMtnB44: all checks on what you stated.
The only way to stiffen the air springs would be to 'fake' higher load (adding salt bags is NOT what I mean), which increases the required pressure for a given height, and consequently a higher spring rate (see graphs in earlier post). The mental picture would be 'rubber bands' around the top/bottom of the bags/suspension parts. Or a 'helper spring' (that pulls the top and bottom together). Neither of those solutions seem practical.
Aside from fluid, an 'insert' would also reduced volume (reduced volume = increased spring rate), but even less practical (Arnott went that way by making he 'piston' larger (= more displacement volume for given travel).
If the Arnott springs are 30% stiffer, the shocks (I'd say at least the rebound rate) should have 30% more dampening as well.
Pretty sure this explains the 'bounce' I currently experience (underdampened front from combination higher spring rate with stock rebound rate).
If the Bilstein Arnott shocks are not 'custom' made for Arnott: has someone seen information on the Bilstein shocks elsewhere?
#14
Are the Arnott Gen II springs not stiff enough for you? Personally I can't imagine having any stiffer springs up front, as on the really bumpy roads we have around here the ride quality is already poor. I think what would be more important is increased damping in both compression and rebound, which would give a firmer feel and reduce bouncing. Traditional suspension setup is always a compromise though.
We need these shocks as an option.
http://www.activeshock.com/
#15
You could possibly increase your damping in the rear by modding that PDC valve throttle. If you could decrease flow through the PDC it'd increase the rear damping.
I found another explanation for the PDC which helped me.
http://www.dynarev.com/Audi_fuel_exhaust.html
...I learn something new every day
#16
They are certainly not TOO stiff for me. Until I have seen/felt 'too stiff', I can't really say.
Yup. My desire for 'firmer' may actually come from 'not enough dampening'!
bilbo6209
09-09-2015 01:28 PM
Inyoury
A6 (C7 Platform) Discussion
13
09-08-2015 05:04 AM
