All Cylinders misfiring
One week ago I changed two coil packs on my 03 AR. Before that the engine started shaking under acceleration and CEL came on (solid). I scanned for the faults and it showed cylinders 2 and 5 misfiring. Those are the ones that I replaced.
Everything was fine until today, the engine started shaking again and this time the CEL was flashing and never turned solid. I had to drive about 15 miles to get home and when I finally got home I scanned for the faults - it showed all 6 cylinders misfiring. I erased the faults and started the car again, run it for 2 minutes. The CEL was flashing again and when I scanned it showed that only cylinder 4 was misfiring.
Do you guys think that CP#4 is the problem or it could be something more complicated? Is this a usual thing that three CP's can fail basically within one week?
you a read out of misfire for each cylinder, don't trust it at idle, they all misfire at idle speed.
Find the culprit while driving with the VAG, since the CP's are grounded by the engine/chassis, usually one bad CP has a following CP, mostly the very next cylinder in line.
So when 2 show misfire at idle, it is usually only the one with the higher misfire count but it will need replacement a.s.a.p because it could trigger to fault the CP next to it......don't ask me why but BTDT ;-)
Consider CP's as wear and tear items, they do fail but not as much as in the 3.0 or 1.8T engines.
when one misfires, the system attempt to correft it by adjusting timing all over. This results in the code for all cylinders missfiring butr the caus is only the one with the code.
At this point a dealer would replace all the remaining CPs. I just paid about 23.00 each from carson@riversideaudi.com
...if the new coil pack has black plastic, it is NOT the latest upgraded replacement part. The correct ones should have red-orange plastic.
Max_Power
11
04-24-2009 11:42 AM
MeehowTT
04-13-2009 05:52 PM
SilverSchwinn
02-13-2008 10:33 AM
Excellr-A8
10-23-2006 07:16 PM
