The allineedtogetrimsonthedangcarlist. I'm i missing anything?
4 H&R 10mm hub. spacers
4 18x8 OZ Superleggera's 5x112 32 offset
4 245/45/18 pilot sport A/S
20 37mm bolts
is that everything? Will this be able to house the stoptech 332mm kit? enlighten me oh wise ones...
20 37mm bolts
Why not go with performance rubber on the OZ's and winter rubber on the stock wheels? Also remember you still need the hubcentric rings for the wheels.
if you mounted the superleggera's without spacers the wheel would not be hubcentric, so you need rings. The spacers are hubcentric to the hub and to the STOCK wheel. So the superleggera still needs the rings to fit the spacer properly. Does that make sense? Other way to go is to have a custom spacer made so it would fit both the superleggera and the hub. The rings are from OZ and specifically for that wheel and are high quality not plastic cheapo rings.
just order the wheel you want with hubcentric rings, they come from the same place and are designed to fit your car with that wheel. Then order the spacers you want with the bolts from H&R. By the way H&R recomended the 15mm spacer and said that was what they were fitting to the allroad.
JoeyVee
05-30-2007 02:09 PM
SHUDS4
05-12-2007 07:17 PM
sbmrinaldi
Audi allroad
12
01-06-2006 12:58 PM
