Allroad 3.0 Tdi Cranks but wont start !!
Hi all
I have a 2006 Allroad 3.0 tdi, It was running fine until the battery went low ( Current drain ) and set the alarm off, I unlocked it with the key fob to disable the alarm and left it until the next day.when I tried to start it it cranked but wont start.
I have checked the fuses and all ok I have replaced the fuel pump relay ,I have checked the electrical feed to the fuel pump and it is supplying 12v on cranking
I have connected an obd scanner and there are no dtc stored in the ecu , the readiness test showed the fuel and egr system as not ready.
The scanner did show " P1653 read dtc memory of abs cm " and " 01314 engine control module "
I also fitted a new battery
I have also left it for 15 minutes with the ignition on before trying to start it
Any ideas on where to go with this ?
Thanks in advance for any help
Graeme
Graeme
UrS4boy
Audi Original "S" Cars
11-03-2014 07:15 AM
twentysevenlitres
22
05-31-2013 09:31 AM
