allroad gurus, can smb provide such tech details as transmission ratios, final ratios for manual
and tiptronic. Also is there a difference in ratios between 2.7 tip and 4.2 trannies. I would also like to compare those to A6 and S4's. Where can i find this kind of info?
<ul><li><a href="https://www.audiworld.com/model/allroad/04/specs.shtml">https://www.audiworld.com/model/allroad/04/specs.shtml</a></li></ul>
(4:1) trannys. I find it hard to believe. It should be either the same or 4.2 has to have lower final ratio like S6 does. Misprint? I'll check RPMs at 50mph on both tomorrow. The brake size misprint makes me suspicious in accuracy of those documents (rears same size in inches, different in metric). Also in S4 papers the auto transmission column is messed up. Some documents!
I wonder if there is some other source?
karizma23
06-07-2007 04:59 AM
