allroad with new thule roof box
#11
DWH - I can't see your antenna, did you take it off or have a smaller replacement. I contacted Rally in FLA and they said that the short antenna (on Griffinpup's rig) was avail thru Kmart and Walmart, but no luck. I'd like to slide my box back just a bit, but right now I'd have to take off the antenna. Anyone else in this thread have any luck on finding a short stubby for the rear antenna?
01/Silver w/Tip/Loaded
#12
I'm trying to decide between gray or beige and have not seen a beige in person. If beige, are you happy with the color and the light interior?
I have a Black/Black A4 and would prefer a light interior thanks to my ever shedding yellow lab. Thanks!
#16
yellow internal reflector? If you got an aftermarket turn signal, were did you get it? thanks...
#18
Only just noticed they're different. Looking from the front the blinker is covered by a reflector. It seems that Rod in New Zealand and myself in Australia have the same blinkers. It may be how the european allroad's are.
#20
Incase you didn't see my post above; You can use the one from a TT Coupe (Part No: 8N8-051-849).
Its short enough that a packasport will fit nicely with about 10-15mm clearance. The antena is pretty sleak looking black metal.
