Allroad problem with ESP light YAW sensor
I have a problem with the ESP ABS light.
I changed the ABS sensor and now that is good but i get
01542 - Yaw Rate Sensor (G202)
37 - 00 - Faulty
And my questions are where the YAW sensor is located?
Any tips on fixes beside changing the sensor
And can the part be changed with same sensor or does it need to be calibrated?
Audi Allroad 2001 2,7t
37 - 00 - Faulty
https://www.audiworld.com/forums/a6-...-seat-1711036/
Basic Setting
Steering Angle Sensor (G85) Calibration
[Select]
[03 - ABS Brakes]
Turn steering wheel at least 30 ° left and back straight ahead.
[Security Access - 16]
Enter 40168
[Do It!]
[Basic Settings - 04]
Group 001
[Go!]
Activate the Basic Setting.
[ON/OFF/Next]
After a successful basic setting, field 3 should say "OK".
[Done, Go Back]
[Fault Codes - 02]
All fault codes should have disappeared.
[Done, Go Back]
[Close Controller, Go Back - 06]
Basic Setting
[Select]
[03 - ABS Brakes]
Enter 40168
[Do It!]
Group 001
[Go!]
[ON/OFF/Next]
[Done, Go Back]
[Fault Codes - 02]
[Done, Go Back]
Basic Setting
[Select]
[03 - ABS Brakes]
Enter 40168
[Do It!]
Group 001
[Go!]
[ON/OFF/Next]
[Done, Go Back]
[Fault Codes - 02]
[Done, Go Back]
Basic Setting
[Select]
[03 - ABS Brakes]
Enter 40168
[Do It!]
Group 001
[Go!]
[ON/OFF/Next]
[Done, Go Back]
[Fault Codes - 02]
[Done, Go Back]
About the calibration, is it the same thing? steering angle sensor and the YAW sensor?
Thanks alot.
When i get
37 - 00 - Faulty
Could the sensor have been damaged by a faulty ABS sensor? Are the wires from the ABS sensor connected to the YAW sensor?
For me faulty mean that the sensor is dead, maybe i am wrong?
Finally i got a ABS sensor from Spain that is working but maybe the wire (if it connects) to the YAW was damaged?
Any tip where to look?
When i get
37 - 00 - Faulty
With these cars, there is no easy way to tell. You have to test each component separately to ensure they are working individually. The Ross Tech link had a diagnostic link. Follow that, and test your systems out. This is impossible to troubleshoot online.
