allroad suspension problem - newbie needs advice
My 2001 2.7T allroad has a suspension problem - the front suspension slumps when parked and leaves both the front wheel arches resting on the tyres
When I start the car the pump raises the front but it takes 5 minutes and the compressor is very noisy
I have owned allroad from new - 43,000 miles on clock - don't have any CPO/warranty remaining
Took the car into my local dealer who replaced the front driver's side air spring - with labour this cost me £576 (that's >$1,000!)
They tested the suspension and advised it was OK - now 2 weeks later the fault is back and worse than before - I leave the car for 10 minutes and its fully slumped!
I've read some of this site's earlier threads on DIY replacement of air springs but don't think I'm up to doing that myself
Don't want to get fleeced (ripped off) by the Audi Dealer again so seeking advice on what the cause of the slumping is - and how to fix it without spending another $1,000
Any assistance/advice gratefully received
DJAH
DJAH
So I'd need another new air-spring at £576 (>$1,000)- passenger side - and how do I tell if the compressor pump is bust? Dealer replacement cost on the pump is >$2,000 here in the UK !
DJAH
DJAH
When I'm diagnosing a compressor problem I look for the pump to produce 7-15 BAR, and not run so much that it times out. Now It needs to not be leaking at any of the springs or the compressor vent valve. This also goes bad , and bleeds the residual pressure out of the system. It should hold anywhere from 4-15 BAR after the pump shuts off. None of this gaurantees a sucsessful repair. All the dealer techs I have talked to basicly replace the compressor and valve body and call it a day. This IS REAL expensive, but under warranty no one cares. Now out of pocket...well. You need to run the output self tests as a start and post your results, we'll go from there.
have you taken yours into a dealer for diagnosis?
what's their suggested remedy??
was hoping for some advice from the forum on a low cost fix - but so far just have advice to replace second front air-spring and possibly the air compressor - at significant expense!
as they tend to go bad close together. I also suggested you start diagnosing the problems with an ouput state check. If you don't have a VW1551/2, Prodiag, or VagCom, there is little any of us can do to help you.
free advice and he not only works on these cars in his own shop but has owned two (three?) of them...pay close attention, also the search is your friend as you will see that the suspension and its attendant parts are a very sophisticated set of parts and the diagnosis is difficult at best...what ex-Pz said is that YOUR dealer will simply throw parts at the problem at your expense....find a good individual shop that works on German cars, preferably Audi's and save yourself some money and some problems. Good luck.
