allroad turbo failure
Newbie on this forum. I won't go into details of my long story - but our allroad had a turbo failure, resulting in a lot of oil being sucked into the intercooler hose. The warranty had just expired. Both turbos were replaced - Audi of America covered the cost of the turbos, but no other parts and no labour.
The end result is I've got a $7400 CAD bill for a car with 89K km.
2 questions: is turbo failure common? and why were so many other parts required to replace 2 turbos? example, 2 camshaft adjusters were replaced etc. etc.
Grateful for any help...
Its just like a starter, or a power sterring pump..some go some don't, nommater how good you are..or aren't. The specifiction is is one goes both get replaced.
Removing the engine is the normal way to do it. While it out they can see all about the engine..
Perhaps the turbos were the symptom and something else happend?
But...the labor portion of the turbo job is 21 hours ad to this about 3 hours for the cam adusters and alignment of your wheels (required) and the worst case is 25 hours?..what is your labor rate in CA?
And there are numerous other things that should be done "while you are in there" which probably explains your lengthy parts list. Without more information it is hard to tell how badly you got ripped off. Unfortunately best case scenario is that the dealer did the job to spec and you still get ripped off as the dealer retail parts price and labor rate is so high. You should never let a dealer do this kind of work on your car.
It is not an issolated issue as it does happen. Me, Dangerman (x2), and a few others I think on the ar forum , then add to this the A6 board and the reckless on th S4 board.
I've posted this before but when I researched this issue there were quite a few to my thinking...it happened to me at 60k and on my '01 it was completely covered as that issue was covered to 80k...my only problem was being without my ar for a week...sweet A4 2.0T quattro to drive so I didn't mind too much (it didn't snow at least
but I think you could have had more of this paid for, IMO.
2low4snow
18
02-07-2005 01:30 AM
q2quest
16
04-14-2004 10:18 AM
BaysideRS4
20
07-03-2001 02:35 PM
AK AL
9
11-02-2000 02:13 PM
