Another newbie Q: STFA yields conflicting results: Does the 628 relay (I have 628, not the 605)
boost steering at ALL speeds? Some archive posts seem to suggest that Servotronic even boosts steering at highway speeds, while others suggest that it makes no difference at higher speeds.
P.S. Has anyone done the Tiptronic 605 switch mod? I don't understand where the "octopus" comes from
These instructions seem to suggest that you have to purchase the "octopus" (i.e. it's listed under the "What you get" section), but I have no idea where to even begin to find that. Otherwise, the article doesn't describe how you would construct the "octopus" assembly.
Am I missing something?<ul><li><a href="http://home.earthlink.net/~oxy8384/605mod.htm">Tip 605 relay switch instructions</a></li></ul>
don't need the octopus
that guy was disabling the 605/628 relay when car was put in TIP mode.
Just pull the relay -- drive around for a few weeks and see how you like it. If too heavy, then all you need to to do is wire an interrupt into the black 12V wire via a toggle switch. Then you can turn the relay on/off via a dash switch.
I understand that I can put in a simple interrupt switch, but I WANT the Tiptronic to control the
relay. Most of the time, I'm driving in Tip mode, and I don't want Servotronic.
If I'm in a parking lot steering around, I want to be able to put it in auto mode and get the 628 back.
I have too many extra switches as it is (one for V1 / Blinder, another for a backup camera), and I don't need another one for Servotronic. I'll get confused as to which one is for what.
SKIroad'r
Audi allroad
06-16-2008 07:10 PM
Boston Driver
11-25-2004 06:53 AM
Troy H
Audi allroad
05-28-2003 06:08 AM
Stoney
07-10-2002 03:56 PM
WildBlueYonder
Performance and Tuning
08-14-2001 06:48 PM
