Another Suspension Level problem...
2005 Allroad - 2.7
I have the Gen II bags on my car, had replaced OEM's about a year ago. My air pump has been getting weak and recently my passenger front shock blew. I called Arnott and got a replacement Billstein. Installed the new shock and rebuilt the pump on Saturday.
Here's my problem: After installation, I let the car down to 'ride height'. I turned on the car and the pump kicked on. It ran for a while then turned off and gave me the error light. I tried it several times and nothing. I let the jack down and the front of the car went all the way to the ground. I jacked it back up and took the car out of 'jack mode'. I tried the levels again and the rear has pressure but the front does not. The passenger front has no pressure at all (the one I replaced the shock in), the driver side front has pressure but not enough to keep the car up. I double checked all the connectors and do not hear any air leaks.
Did I mess up by taking the car out of 'jack mode'? I do not have a vagcom, trying to get access to one.
2005 Allroad - 2.7
There are no leaks that I can find in the front. The passenger front has no pressure at all and no air is coming through the line. The driver front has some pressure and is holding but will not raise car.
did you buy the kit from me?
regards
Andy (bagpipingandy)
It is your kit. I paid close attention to the ring when installing. Looked to me as if it would only fit correctly one way anyway. I found someone with a vagcom to come scan/reset the car tomorrow. If that doesn't fix it I may pull the pump apart (hopefully in the car this time) and double check the ring, but I'm positive it's installed correctly.
Can you hear air escaping when the front is trying to lift, the one strut you changed it could leak past the o-ring which would loose air but with your ear in close and the compressor running i would expect to hear the air whooshing.
try your finger over the compressor output it should blow your finger off the end if all healthy.
regards
andy
regards
andy
I had a thought that maybe moisture froze in the line. So I heated my garage to 70*f for a couple hours then tried it. Still not working.
Andy, I did listen for leaks, could not hear any.
Another odd behavior I witnessed. When attempting to get the car to go to level 2 last night, the front would not go up at all. The rear would go up past level 2, at least an inch past.
I have someone coming over today with a vagcom. I'll report back after that.
If air is coming from the line, you have a Leak in your assembly. Did you grease the top O-ring?
If no air is coming out, scan the car for sensor height values. You can try disconnecting the level control module and connecting it back, to "reset" it.
Yes, I am going to check for leaks today. I did grease the top o-ring. I found this today, seems helpful.
http://www.volkspage.net/technik/ssp/ssp/SSP_243.pdf
Here are the codes I pulled yesterday. Resetting them did not help.
VCDS-Lite Version: Release 1.1
Thursday, 09 January 2014, 14:46:07:38157
Control Module Part Number: 4Z7 907 553 Fâu
Component and/or Version: - 2C1A1 D060
Software Coding: 25500
Work Shop Code: WSC 02334
VCID: 9F3175720EB3
3 Faults Found:
01400 - Suspension Level Control
11-10 - Control Limit Not Reached - Intermittent
01577 - Turn-Off due to Over-Temp
35-10 - - - Intermittent
02538 - Function Restriction due to Overload
Thursday, 09 January 2014, 14:50:08:38157
VCID: 9F3175720EB3
1 Fault Found:
11-00 - Control Limit Not Reached
VCID: 9F3175720EB3
3 Faults Found:
VCID: 9F3175720EB3
1 Fault Found:
check compressor output if its strong the ring is fitted ok, the rest is a bit confusing for now but have you had anything else removed, airlines, level sensors or other?
did it work ok before you carried out the work?
what exactly have you removed and re-fitted from the car?
I'm thinking outloud for simple stuff: could front airlines have been swapped with rears? or front level sensor on the wrong way and it thinks it is high, and rear is trying to lift to match??
regards
Andy
regards
Andy
