Another 'suspension wont raise' question
Finally back in an audi! Picked up an 04 allroad 4.2 yesterday. This morning the front suspension is lowered (25* parked outside), looks like the passenger side is resting on the bump stops (drivers side is about 1-2" higher). When I start the car and select level 2 or 3 it will blink green but wont raise. The yellow suspension light flashes but nothing happens. I can hear what I believe to be the compressor working but am unsure where to go from here and have a few questions.
1) Is there a way to get the car to raise so I can test to see if it will hold air on setting 3 or 4? i.e. jacking up the front end or something like that?
2) Is it okay to drive with the suspension bottomed out in the front (normal roads to and from work).
3) What else can I check before purchasing new airbags? I want to make sure I'm not just replacing airbags without first understanding if they are indeed faulty. The PO did have the airbags replaced but it was about 5 years ago.
4) Is there a preferred replacement airbag? I see generic no name brands on Amazon for as little as $130 ea and I also see the Arnott A-2869 for $280.
Any help wold be appreciated, thanks!
Banned
the front gen 1 bags just got an update to the design, slapped a pair on my ar yesterday.
would also suggest replacing the shocks as well with the new bags, save yourself some labor down the road
Thanks for the help!
I tried the jack but that didn't seem to do the trick. Took it for a slow ride around the neighborhood and it came back up to level 2.
I have it at level 4 now and will see how it does overnight.
Sounds like the Arnott springs may be in my future. May try the green slime trick first to see if that helps me get through the winter.
Morning update - I set the allroad on level 4 at 3pm yesterday. This morning (5am) its still at the same position. Temp yesterday was 34*, this morning its 14*.
Would this point to a leak on another level? It was at level 2 when parked the night before and sunk down to the bump stop on the passenger front side.
my mechanic shop is the best in CT for these cars, and they know their stuff.
best regards
Andy
Just to jump in on this thread, I replaced my two front bags last winter and haven't had any issues. Two days ago, I parked my 05 allroad in the driveway. Came out in the morning and the front end is on the ground. It was 14 degrees out. I started the car, the suspension light would flash for a couple of minutes then turn solid. The front end did not come up at all. What should I try next?
Banned
get it vagcom'ed and report pack
but seeing how it didnt raise at all i could be either the compressor or the suspension computer has failed.
