Any way to manually move a power seat back? My passenger seat just
stopped sliding forward or back (everything else works though). It is all the way forwad and I have a 5 hour drive tomorrow for my wife and it won't be comfortable...
Do the buttons for seat adjustment still light up on door when you turn your dash lights on?
If not electrical connector in door may have came apart. Only takes five minutes to pull door panel off. 2 philips screws, 1 on front of door at top, and 1 at back of door at top. Then lift up on whole panel to remove. Then check connectors.
Buttons are lit and all seat functions work except for and aft movement ...all I here is a
slight 'click' out of the seat switch when I try to move it...maybe that switch relay under the seat is broke...?
