Anybody have diagram of the air suspension system? P&ID?
#11
Just got the car back from the dealer. After lots of investigation and 1.5hrs shop rate, it turns out there is a 40 amp fuse under the hood behind a relay box The fuse protects the compressor motor. It took a few calls with Audi dealer tech support for the mechanic to find the fuse. Apparently when the old compressor prssure switch failed, and the pump ran without kicking off due to over temp, the fuse blew???
Everything is working well now. Time for a new Audi. I think a 2007 A6 Avant with 3.2L and Premium package.
SST
SST
#12
Does anyone know the thread size/pitch for the connections to the valve body? I'm buying a allroad which I believe has a bad compressor and I need to bypass the compressor and inflate the bags with a small portable compressor.
thanks
thanks
#13
Why dont you call Arnott and order the mercedes compressor and overnight it? I think arS6 over at QW can help though. See his thread here:
http://forums.quattroworld.com/allroad/msgs/42362.phtml
#14
Thanks. I haven't diagnosed the problem yet, I'm just suspecting it's the air compressor, and most likely due to a leak somewhere else in the system. I want to pick the car up this weekend and want to just plug my compressor into the cigarette lighter, connect to the inlet fitting on the valve block and inflate all the bags. Then I can cycle the compressor on/off throughout the drive home when/if the bags start to deflate. Might have to slime them. Audi has the fittings, but they are like $60 for two which is ridiculous. I may just disconnect the line from the compressor, slide a larger ID tube over the end and triple clamp it.
#15
SST
SST
#18
To provide vaualbe info to this thread, I thought I would post this link from Blauparts, to help with troublehooting suspension issues. It has a lot of important details and pictures to help any DIY'ers sort out their issues.
http://www.blauparts.com/audi_allroa...rsion_kit.html
#19
<img src="http://pictureposter.audiworld.com/56080/level_control.jpg">
Pneumatic level control (allroad)
Component locations
1 - Right front air strut
2 - Operating unit
3 - Right rear air strut
4 - Right rear level control system sensor -G77-
5 - Control module
6 - Pressure reservoir
7 - Left rear level control system sensor -G76-
8 - Left rear air strut
9 - Air supply unit with:
Compressor
Vent valve
Lateral check-valves
Temperature sensor
Pressure sensor
Auxiliary noise insulation
10 - Electric/pneumatic lines
11 - Left front air strut
12 - Left front level control system sensor -G78-
13 - Right front level control system sensor -G289-
Component locations
2 - Operating unit
5 - Control module
Compressor
Vent valve
Temperature sensor
Pressure sensor
#20
i will try to attach below
Suspension.pdf
page 3 starts to show valve block 10 pin wiring plug any thing with "T10bb" is the 10-pin connector on the valve block
it has all pin numbers, colours and info you need
regards
Andy
