Anyone have good results painting trim using the paint spray can kit sold in paintscratch.com?..
I just bought the used ABT front grill advertised in AW. I need to sand and repaint. Can I DIY the paint process using the spray kit or should I leave this to the pros?
and paint. I've used Wurth paint products with really good results. In fact, refinished my original twin spoke outer face and center caps this past winter with the Wurth silver and clear. Look great, and can be wet sanded and polished later too.
over it. 1 is safe for spraying over both, but I can't recall which 1.<ul><li><a href="http://www.wurthusa.com/project/en/leftnavi/catalog/product.php?path=04.0240.jpg">http://www.wurthusa.com/project/en/leftnavi/catalog/product.php?path=04.0240.jpg</a</li></ul>
is put on real heavy (in a sense slowing the flash off time). So, if you spray on light coats it can be done (if no broken edges).
Also on a grille, I would personally use a rubber additive in the paint to help reduce chipping (leading edge scenerio).
between coats.... that has always worked well for me. But I also have a compressor and air brush to carefully apply primer if the shaker can doesn't work.
in the industry. I started painting back in the '70's just as Dupont was bringing Imron to the market. Used to paint with just a respirator and a fan to keep the fumes in control. Man, what I'd have given for today's downdraft climate controlled booths with ventilators. Still have an ancient Devilbiss spray gun that I use for simple things like painting a helmet or a suspension part.
rexti_98
03-14-2004 11:29 AM
Projekt 8E
11
11-20-2003 07:19 AM
TTS_4_to_A6
08-09-2002 09:37 AM
