Anyone know any useful function by changing code via VAG-COM?
Just wanna know and try any other interesting function to modify via the coding of modules to enable/disable options by VAG-COM except 402 mods.
i.e. auto-lock for ar.
Actually i have only tried height control module, but no experience for any other modifying some options programed into the control modules.
Will be grateful if i can receive any advise by brains and how to do it.
Thnx.
Thnx.
Thnx.
Thnx.
http://allroadfaq.com/howto/vagcom.shtml
I recoded the convenience control module and it is great. At 15 mph all doors lock. When you turn the car off and remove the keys from the ignition all doors unlock. If you hold the key fob door lock button for 5 seconds all windows and moon roof automatically close. If you hold the key fob unlock all windows open. I used code 15977.
Good luck!
-Mike
Good luck!
-Mike
Maybe will try coding "14953" onto the central lock mods later.
According to Ross-Tech information as below,
looks possilbe to change the idling speed.
http://www.ross-tech.com/vag-com/cars/audiB5.html
Is this adaptable to our C5 allroad?
Just curious about changing start moving torque or idling mileage, if it can.
Any opinions?
Any opinions?
Today is national holiday as Culture Day in Japan.
Tried Vaging to change the idling speed, and resulted in success!
Original setting value was "128" and speed was around 700rpm.
Changed to "124" and speed is now around 650-660rpm. (Of course lower!)
Engine feeling had been totally changed.
Idling became quiter than before.
Before changing this setting, always felt that start moving torque was too strong and very difficult to control stepping the gas pedal not to be too much speeding when i start my babe.
However now i got much better feeling than before.
Very easy to control it.
Additionally IMO engine feeling is also smoother than before.
Expecting being improved the gas mileage now.
Strongly recommend to try this.
P.S.
Already succeeded in auto-lock as well.
Thnx.
P.S.
Thnx.
technics100
06-28-2005 07:00 PM
JimOB
11-06-2000 09:16 AM
