APR CHIP Boost test with VAG-COM
Has anyone done a boost comparison between the 91 octane APR program and the stock program? Does the VAG-COM give accurate readings for this parameter?
The APR chip is supposed to be in a 1 bar configuration. This would mean the Boost as read by the VAG-COM should be ~2000 mbar. Logs of my boost show readings in the 1700 mbar range which makes me think that I have a boost leak...
Thanks in advance!
Thanks in advance!
I don't have VAG com, but my friend does, just waiting to find time. If you want to run with me sometime, we can compare results....what part of town are you in? I am in Westminster
cheers
jon
cheers
jon
STOCK:
<img src="http://mywebpages.comcast.net/ryanjen1/allroad/VAG-COM/tryagainplot.jpg">
GIAC CHIP:
<img src="http://mywebpages.comcast.net/ryanjen1/allroad/4th_gear_pull_new_O2S.jpg">
GIAC CHIP:
Peaks out around 3000 RPM between 1700 and 1800 mbar then is pretty level (low 1700s) up to ~6000 RPM.
mbar reading. 1000 mbars(1 bar) over 840 is 1840 mbars so you chipped readings appear to be close to right. if requested and actual boost stay within 100 mbars of each other from 3000 rpms up i would guess there is nothing wrong. the stock mbar reading is the one i don't get.
mtaesch (Matt T)
VAG-COM Discussion
12-28-2005 02:28 PM
jprice@CPS
02-10-2005 01:59 PM
