ON the AT5 transmission is there a low fluid sensor that will put out a tranny code?
I've been monitoring the tranny pan cover and there is some fluid around the gasket. I will be replacing the fluid,filter and gasket in a month or so. I am just worried if the fluid is actually leaking will I get a warning code if the fluid gets dangerously low?
Re: ON the AT5 transmission is there a low fluid sensor that will put out a tranny code?
I know nothing about low level sensors on the trans. I noticed in your signature that your 02 TIP is recoded-shift on the fly. How and where did you get that done?
Thanks
Thanks
No sensor that I know of. Even if it is leaking & it's just a little oily thats not likely enough fluid loss to be worried about between now & when you get the service. When you leave trans. fluid on the ground then worry.
Vag com...
only works if you have the gear shift buttons on the multifunction steering wheel.<ul><li><a href="http://allroadfaq.com/content/tip_recode.shtml">http://allroadfaq.com/content/tip_recode.shtml</a</li></ul>
krolls
Audi 100 / A6 (C4 Platform)
02-01-2008 12:52 PM
