Audi A6 - gear stuck on park when the ignition is on or car is on
Audi a6, quattro 2.7t, 2003 has gear lever problem,
When the ignition is on, the brake shoe light on the console is illuminated but the car will not shift even by depressing the break all the way, when the illumination goes off after a few minutes, I am able to shift
The ABS error is on the dashboard
And nowadays the car lurches forward when I shift to drive or reverse
The brake lights work
I have replaced the brake light switch but no success.
When the illumination on the brakeshoe goes off, I can shift the gear without a problem
Sometimes, I have had to restart the car several times.
This is the error from vag-com
18034 - Powertrain Data Bus: Missing Message from TCU P1626 - 35-00 -
I have checked nearly all fuses, by removing them one by one, cannot seem to see any bad ones
i had that on my 2001 a6 quattro, it was to things i did, changes the bulb holders for the right back side and the air massmeter then my car stopped to crak into gear and stopped locking the gear, another friend he had floded car the drain under the winshield wiper was blocked and he had water in the car and his car did what you tell now
Audi A4 2003 Audi A4 Avant 5 speed
Teamelevation
11-21-2015 07:37 AM
Gail Baker
10-06-2015 04:41 PM
