Audi Allroad 2.5 td rpm problem
I have a problem, Audi Allroad 2.5 diesel v6 engine PSG5 pump 2004 year. sometimes the base gas does not go back until 1200 rpm and the engine shakes, when I give gas then the engine shakes up to 2000 rpm. There is no error code. Ignition timing is good. When I test it with VCDS, the timing still raises the revolutions to 1200, you can hear that the timing is changing, but the engine works fine. I can't find the cause of the error. Does anyone have experience with such a case?
DaveyKid
06-13-2004 05:55 PM
1.8T motor Idle problem -more frequent swings between 2000 rpm and 200 rpm on cold starts any ideas?
TTeleven
04-11-2001 09:06 AM
TTeleven
04-11-2001 04:43 AM
