Been dealing with this over the last week...
On starup and now when the car is first rolling (first 5 minutes)... The shift lock light/relay begins clicking once per second, the three light salute (ABS, Level, ESP) stays on and the Engine MIL flashes While this is going on and then goes out when the car settles. Car goes in and out of gear.
Checked connection to the TCU and ABS and all seem good. ABS module replaced 1 year ago. I would somewhat expect the tranny to go into linmp mode if the TCU was bad. I do have a GIAC chip socketed to the TCU. I opened up the TCU to check the chip and it was nominal.
Codes:
Address 03: ABS Brakes
Part No: 4Z7 907 389 A
Component: ABS/ESP allrad D55
Coding: 06497
Shop #: WSC 26131
1 Fault Found:
18034 - Powertrain Data Bus: Missing Message from TCU
P1626 - 35-00 - -
Address 17: Instruments
Part No: 4B0 920 981 P
Component: KOMBI+WEGFAHRS. VDO D11
Coding: 06264
Shop #: WSC 26131
WA1YD64B32N143739 AUZ7Z0B2113165
1 Fault Found:
01315 - Transmission Control Module
49-10 - No Communications - Intermittent
Codes:
Coding: 06497
Shop #: WSC 26131
1 Fault Found:
P1626 - 35-00 - -
Coding: 06264
Shop #: WSC 26131
1 Fault Found:
I replaced that switch about 6 months ago... I certainly wasn't getting these codes then but worth a try since I have a spare switch in stock.
Anyone else?
Anyone else?
nt2old4ns4
05-19-2006 05:44 AM
algisas
Audi 100 / A6 (C4 Platform)
11-21-2005 07:45 AM
