Best Brand/Viscosity Oil for AR
Old 01-31-2011, 07:02 AM
STL_allroad's Avatar
Default Best Brand/Viscosity Oil for AR
I am going to attempt to change my own oil. I was wonder what brand and viscosity people have best results with. I will choose between the audi speced oils that are fully synthetic. What brand do most people like. Is 5W-30 decent for the midwest? 5W-40? Thanks in advance.
Old 01-31-2011, 07:08 AM
09mehashaw's Avatar
This should help...
http://www.audiction.com/audi-mainte...7t-oil-change/
And here's a link located in the page:
http://microsites.audiusa.com/ngw/09..._1997-2010.pdf
Hope this helps and have fun buddy.
Old 01-31-2011, 08:19 AM
I have seen both of those, thank you though. I am trying to hear some opinions on peoples prefered oils...
Old 01-31-2011, 10:37 AM
5v/cyl's Avatar
German Castrol 0w-30 is popular around here. Get at Autozone. Must say 'European formula' on the front and 'Made in Germany' on the back. Amsoil Euro 5w-40 is also great oil. Mann filter is a must.
Old 01-31-2011, 10:41 AM
jeffco50's Avatar
Default Not on the "list"
But, the Rotella T Syn 5w-40 is great oil. Blackstone reports support this in my 2004 2.7t ar.
I've also used Syntec and M1. My car uses/loses?? M1 @ a rate of 1/2 qt every 5k. This does not happen w/ the Shell or Castrol.
Don't know where the M1 goes but it does. I've used it twice with Rotella in between (no need to top off the Rotella)
Anyone else have a M1 issue?
Old 01-31-2011, 12:13 PM
5v/cyl's Avatar
If by M1 you are referring to Mobil 1 5w-30 then that stuff is junk. It shears out of grade in a couple thousand miles and turns to water. Tried it once in my 2.8 A4 and valve train was noisy. Changed to GC and everything went nice and quiet again. Mobil 0w-40 is supposed to be much better.
Old 01-31-2011, 06:03 PM
I picked up the euro castrol full synthetic. How do I know where the max level mark is (referring to the caution on my oil cap). How much is too much so as not to cause catalytic converter damage?
Old 02-01-2011, 02:14 AM
5v/cyl's Avatar
Should only take 7.3 qts w/filter. Hatched area on the dipstick is safe range. Touching the top plastic piece one the end of dipstick is absolute max.
Old 02-01-2011, 05:59 AM
JustMtnB44's Avatar
I used the German Castrol Syntec 0W-30 last time, and will probably use it again as I am due for an oil change. I have a 4.2 and change it every 10k miles, and over that time period it does not use or lose any oil.
Old 02-01-2011, 06:26 AM
Your lucky. I bought my allroad and discovered a oil leak and then discovered its not covered under warrenty and that its $1200 to fix. I can buy alot of bottles of oil for $1200...
Quick Reply: Best Brand/Viscosity Oil for AR
