Last edit by: IB Advertising
- Audi A6 C5 How to Install Bluetooth<br>Step by step instructions for do-it-yourself repairs.
Best way to integrate Bluetooth with Symphony II and Bose
I used to have an 03, now I've just picked up an 02 Allroad with Bose Symphony II.
I would like to integrate Bluetooth so I can use my iPhone. I would like to be as OEM as possible, use the MFSW controls and see callers in the dash display.
Can this be done?
Can this be done?
it's not that hard to install, but depending on where you're located, there might be someone local who has done this before. Also check out www.audiforum.us for some more info on this.
there are some resources for you there. I bought mine form a seller named "Proxus" - his whole business is sourcing RNS-Es for the various models and selling them.
mount the OEM BT module, behind the glovebox, and run the mic wire up the passenger A pillar (see tech section).
You'll need:
1) a new domelight panel ($50) to house the oem mic
2) BT module: $300+
3) BT antenna: $15
4) OEM mic and wiring harness: $200-ish
You need to tap into 8 wires behind your Sym II to make this work and recode (VAG) your MFSW for phone control etc.
It's a bit pricey if you want to stay OEM but very doable. I think I have the parts in stock to build this for you if you like -- you'll just need to source some of the parts on your own.
Good luck!
-Ted
You'll need:
2) BT module: $300+
3) BT antenna: $15
Good luck!
-Ted
