Old 07-25-2016, 03:21 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:Browse all: Audi A6 (C5) Brake Guides
Print Wikipost
Brake light switch - DIY instructions? Where to get part?
Old 03-29-2009, 02:44 PM
snokarver's Avatar
Default Brake light switch - DIY instructions? Where to get part?
I need to replace the brake light switch on my 05. I searched genuineaudiparts but didn't find a switch.
From searching the forum, I've found a few dozen posts that say "search the forum for DYI instructions" but never found a thread that actually had them. A couple said it's easy.
Anyone have a link to the instructions?
Thanks.
Old 03-29-2009, 03:11 PM
snokarver's Avatar
Partially answering my own question here - DYI instructions are at http://allroadfaq.com/content/resolu...brlghtsw.shtml
Old 03-29-2009, 04:53 PM
03AR2rescu's Avatar
I just got mine from the dealer, it was only like $35 or so. But you could call Carson @ Riverside, or genuinevwaudiparts.com
Old 03-29-2009, 08:11 PM
paulroad's Avatar
Default piece of cake
paulroad's Avatar
https://www.audiworld.com/forums/alb...ctureid=147642
Old 03-30-2009, 09:57 AM
snokarver's Avatar
So is it not as complex on the allroad as this?
http://forums.vwvortex.com/zerothread?id=1158315
Old 03-30-2009, 11:32 AM
paulroad's Avatar
not at all. but I never did it so its hearsay.
Old 03-30-2009, 01:04 PM
snokarver's Avatar
woah, strange. the dealer just quoted me $4.28. Hmmmm.
Old 03-30-2009, 08:50 PM
kingfishgrapejam's Avatar
those are the correct procedures, it is just easier than it looks.
Old 04-01-2009, 09:01 AM
snokarver's Avatar
Yep. Hardest part was getting the panels off the dash to get to the switch. I used my Bentley dvd to figure that out. Getting the connectors off of the light on the under dash panel was more difficult than installing the switch.
One tip to anyone who does this, use the old switch as a test to install. You just need to make sure it's seated all the way, then turn it. As long as it was aligned right to begin with, it should be fine.
I put mine in, and turned it. That's all it took. Didn't need to adjust the pedal position at all like the vwvortex post says.
Quick Reply: Brake light switch - DIY instructions? Where to get part?
