Old 07-25-2016, 03:21 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:Browse all: Audi A6 (C5) Brake Guides
Print Wikipost
Brake light switch - DIY instructions? Where to get part?
Old 05-31-2009, 02:34 PM
  #11
mindcrash's Avatar
Originally Posted by snokarver
Yep. Hardest part was getting the panels off the dash to get to the switch. I used my Bentley dvd to figure that out. Getting the connectors off of the light on the under dash panel was more difficult than installing the switch.
One tip to anyone who does this, use the old switch as a test to install. You just need to make sure it's seated all the way, then turn it. As long as it was aligned right to begin with, it should be fine.
I put mine in, and turned it. That's all it took. Didn't need to adjust the pedal position at all like the vwvortex post says.
Can you give me some tips from your Bentley DVD? I can't figure out how to take the trim piece off and don't want to damage it.
Old 05-31-2009, 03:01 PM
  #12
allroad(s) lead 2Gavin's Avatar
Default That is the correct price...
woah, strange. the dealer just quoted me $4.28. Hmmmm.
Old 05-31-2009, 04:51 PM
  #13
all123's Avatar
a very lame question here.
What does the brake light switch do?
Old 12-13-2011, 07:25 AM
  #14
kornerstone2's Avatar
Default Brake light switch replacement help
Can anyone give me tips to remove bottom panel?
My 2005 A6 brkae light were on thru the night four days in a row(it does only thru the night). I try to replace brake light switch. I removed two screws from the bottom of the panel and one screw from the side where fuse panel is located. But, still can not remove the bottom panel. I ordered the Bently DVD, but has not arrived yet.Please help me.
Jim4802
07-11-2019 10:38 AM
chokboywonda
06-19-2014 09:54 PM
spokaudi
Audi allroad
02-20-2007 05:44 PM
leTTcco
09-18-2006 01:44 PM
Quick Reply: Brake light switch - DIY instructions? Where to get part?
