Are the brakes on this car really that hard to get correct? Need suggestions>>
Old 09-29-2006, 11:04 AM
  #21
xtreetoes's Avatar
Default I torque them with the tire partially weight loaded.
My routine is to snug the lugs while the tire is in the air, then lower the vehicle enough so the tire touches the ground and won't spin, then torque.
I have found if you let the car all the way down and torque the bolts you can have problems.
Old 09-29-2006, 11:53 AM
  #22
Member
Ex-PzKW Cdr's Avatar
Default Yes I would check for related problems, such as the caliper bushings needing
grease or badly deteriorated. Not everyone is diligent enough, BUT frequently customers think your only trying to pad the bill, it's a fine line.
Old 09-29-2006, 11:55 AM
  #23
Member
Default Ahh a lot of catalogs list the A6 pad for the allroad as well
this is not the case as the location of the clips on the back are somewhat different. I had this problem myself early on. I ordered the A6 pads and cut the clips off the stockers and welded them on the new pads. Worked until the correct pads were available
Old 09-29-2006, 01:07 PM
  #24
Member
girlroad's Avatar
I'd prefer thorough in one trip vs. having to return again and again...
Old 09-29-2006, 01:11 PM
  #25
Member
girlroad's Avatar
Default Mine are already "done" when I double check them, I just make sure they are not too tight or too
loose, the last time they had the wheels off two days later one was so loose it was wobbling
Old 09-29-2006, 01:16 PM
  #26
BonanzaMan's Avatar
2nd...
Old 09-29-2006, 01:21 PM
  #27
Member
girlroad's Avatar
So, for clarification is the number I posted the allroad number? TIA
Old 09-29-2006, 05:06 PM
  #28
mustbeaudi's Avatar
Ah, a professional technique. Now I really need a floor jack, as if I have room for one.
Old 09-29-2006, 10:30 PM
  #29
uber_ar's Avatar
Default Caliper problem.... Piston retraction not correct... sticking. Making the pad
deposit unevenly on the rotor...making a vibration.
Old 09-30-2006, 05:32 AM
  #30
Member
girlroad's Avatar
Default I thought of that, but I thought they might look for that...what is the test for it so I can be more
specific...TIA
Denis54
S4 (B8 Platform) Discussion
05-24-2016 01:17 PM
boricuaA3
Audi A3 / S3 / RS 3
06-18-2009 02:38 PM
stoc005
06-26-2005 04:35 PM
abel2pt8
09-09-2004 11:00 AM
hajami
04-23-2002 06:55 PM
Quick Reply: Are the brakes on this car really that hard to get correct? Need suggestions>>
