Can someone explain some of these codes please?
Address 01: Engine Labels: 078-907-551-AZA.LBL
Part No: 4Z7 907 551 L
Component: 2.7l V6/5VT G 0001
Coding: 06712
Shop #: WSC 40617
WA1YD64B82N040168 AUZ7Z0A1946544
2 Faults Found:
17862 - Exhaust Gas Temp Sensor 1 (G235): Short to Ground
P1454 - 35-00 - -
18062 - Please check DTC Memory of Instrument Cluster
P1654 - 35-10 - - - Intermittent
Readiness: 0000 0000
Address 08: Auto HVAC Labels: None
Part No: 4B0 820 043 AD
Component: A6-Klimavollautomat 0105
Coding: 00010
Shop #: WSC 02325
2 Faults Found:
00785 - Temp Sensor in Instrument Panel (G56)
30-10 - Open or Short to Plus - Intermittent
01272 - Positioning Motor for Central Flap (V70)
41-10 - Blocked or No Voltage - Intermittent
Address 15: Airbags Labels: None
Part No: 4Z7 959 655 E
Component: Airbag 8.4E 3000
Coding: 0000307
Shop #: WSC 02335
1 Fault Found:
01212 - Belt Tensioner Igniter; Rear Passenger Side (N197)
001 - Upper Limit Exceeded - Intermittent
Address 17: Instruments Labels: 4B0-920-xxx-17.LBL
Part No: 4B0 920 981 P
Component: KOMBI+WEGFAHRS. VDO D07
Coding: 06264
Shop #: WSC 06117
1 Fault Found:
01039 - Coolant Temperature Sensor (G2)
Address 36: Seat Mem. Drvr Labels: None
Part No: 4B0 959 760 B
Component: Sitzmemory R1 F 0101
Coding: 00001
Shop #: WSC 00000
1 Fault Found:
01446 - Sensor for Driver Seat; Seatback Adjust (G230)
20-00 - Malfunction in Basic Setting
Are these easy fixes? a friend is looking at purchasing an allroad and these were the codes that came up.
Many thanks in advance.
Coding: 06712
Shop #: WSC 40617
2 Faults Found:
P1454 - 35-00 - -
Coding: 00010
Shop #: WSC 02325
2 Faults Found:
Coding: 0000307
Shop #: WSC 02335
1 Fault Found:
Coding: 06264
Shop #: WSC 06117
1 Fault Found:
Coding: 00001
Shop #: WSC 00000
1 Fault Found:
Thought it was the igniter, but the code cleared on its own and hasn't come back. Talked to a tech friend who claims that if the seatbelt doesn't retract all the way or is wrapped around a car seat too long that a code can result. He claims the system can be flakey - throwing codes that will ultimately clear. If they don't, then you have a genuine issue.
Try clearing it and watching to see if it comes back.
GG
GG
First of all, for those intermittent codes, maybe caused by disconnecting the conectors when repairing.
So, those codes should be cleared, and check again.
- MAYBE G235 need to be replaced.
- Instrument Panel Interior Temperature Sensor -G56- integrated into A/C Control Head -E87-, cannot be replaced individually.
- So, A/C control head -E87- MAYBE need to be replaced.
- MAYBE "basic setting" can solve it. MAYBE motor is bad. MAYBE flap is blocked by something.
- check the connector under the rear seat bench first.
- MAYBE G2 need to be replaced.
0105, 3510, 4b0, 920, 981, a6klimavollautomat, codes, coding, component, coolant, explanation, g2, intermittent, sensor, temperature
