Can't find it! Does anyone have a Hydraulic flow diagram (Power steering etc) to share?
Or...where exactly is the hydraulic pump that moves the Power steering fluid (From-To and anything in between?). And are there other components fed with this system?
Thanks!
Thanks!
powersteering pump :
<img src="http://pictureposter.audiworld.com/56080/power_steering_pump.jpg">
power steering oil circulation :
<img src="http://pictureposter.audiworld.com/56080/power_steering_oil_circulation.jpg">
1 - Power steering gear
2 - Return hose
3 - Expansion hose
4 - Heat shield
5 - Cover with dipstick
6 - Hex bolt, 9 Nm
7 - Power steering fluid reservoir
8 - Rubber bushing
9 - Return hose
10 - Intake hose
11 - Clamp
12 - Clamp
13 - Rubber buffer
14 - Hex-nut, tighten to 9 Nm.
15 - Cooling line
16 - Sleeve
17 - Screw and washer assembly, 9 Nm
18 - Torx bolts (T25)
19 - Line
20 - Intake hose
21 - Power steering pump
22 - Seal, 16 22
23 - Banjo fitting, 47 Nm
24 - Expansion hose
25 - Hex bolt, 7.5 Nm
26 - Union nut
27 - Sheet-metal screw and washer assembly
28 - Heat shield
29 - Spring nut
2 - Return hose
3 - Expansion hose
4 - Heat shield
6 - Hex bolt, 9 Nm
8 - Rubber bushing
9 - Return hose
10 - Intake hose
11 - Clamp
12 - Clamp
13 - Rubber buffer
15 - Cooling line
16 - Sleeve
19 - Line
20 - Intake hose
22 - Seal, 16 22
24 - Expansion hose
26 - Union nut
28 - Heat shield
29 - Spring nut
yyspark
Canadian Discussion
07-20-2004 09:28 AM
azndrunk74
03-09-2004 05:22 AM
Mr.D-'97 A4q 12v
12v V6 Discussion
13
09-10-2003 10:30 AM
Knndad
12-09-2002 10:14 AM
