Car ramps for Oil changes, etc?
Old 01-09-2008, 12:52 PM
Member
AudiCraig's Avatar
Default Car ramps for Oil changes, etc?
After my first oil change with the new car, it seemed a bit tricky to find a good place to position the jack and then replace it with the jackstand. So I was wondering about the good old car ramps and how easy that would be for doing simple maintenance under the vehicle for anything not requiring removal of the wheels. Has anyone tried this? I suppose 'jack-mode' would not be required. Will it monkey with the auto leveling feature?
Just curious how others are doing it.
Old 01-09-2008, 01:03 PM
paulroad's Avatar
Default Car Ramps and the allroad were made for each other...get two sets.
<center><img src="http://pictureposter.audiworld.com/63674/dsc_1933.jpg"></center><p>
Old 01-09-2008, 01:18 PM
gragravar's Avatar
ramps work great
Old 01-09-2008, 01:20 PM
Member
AudiCraig's Avatar
Thanks, those look just like the ramps I'll get.
Old 01-09-2008, 01:30 PM
y'allroad's Avatar
Default thanks for the pic - i knew this was possible, but never tried.
i'm going to upgrade my curbside service center with a second set of ramps. j.
Old 01-09-2008, 01:35 PM
paulroad's Avatar
Default Its a hoot to do and look at...
you ge the feeling as you go on the ramps that the car should not move in this direction...vertical and forward without an incline angle. I did this when I installed the DTS.
Old 01-09-2008, 01:53 PM
Trango's Avatar
About the only maint you can't do on ramps is replacing the inevitable air strut.
Old 01-09-2008, 02:37 PM
allroadCole's Avatar
I use the plastic rino ramps, they work great for oil changes and cleaning/inspecting...
Old 01-09-2008, 02:44 PM
and brakes...
Old 01-09-2008, 03:39 PM
Trango's Avatar
Good call. BTW, the latest Slime project has been holding for 2 weeks + 400ish miles.. stil testing.
Quick Reply: Car ramps for Oil changes, etc?
