Central driveshaft CV joints
Old 04-29-2014, 12:42 PM
AudiQC's Avatar
Default Central driveshaft CV joints
I need to change my front "Central driveshaft CV joint" the one that connect to the transmission. I have checked with BLAUPARTS and they say that they can only supply the axle CV joints for allroad. Is there other part suppliers that sell driveshaft CV joints ??
Regards
Old 04-30-2014, 06:07 AM
G0to60's Avatar
Do you mean one of these?
http://www.europaparts.com/cv-joint-893521100.html
Old 04-30-2014, 06:53 AM
indoor's Avatar
I think he is talking about these:
http://www.ecstuning.com/Audi-All_Ro...s/CV/ES366558/
Or these :
Amazon.com: Febest- Vw Inner Cv Joint Left 34X104 - Oem: 4B0498103: Automotive Amazon.com: Febest- Vw Inner Cv Joint Left 34X104 - Oem: 4B0498103: Automotive
But you are better off buying a new axle. Do you have clunking? How do you know it's toast?
Old 04-30-2014, 08:05 AM
amiram's Avatar
Default prop shaft
Maybe he mean the prop shaft
Old 04-30-2014, 04:24 PM
AudiQC's Avatar
Yes it is the prop shaft
Old 05-01-2014, 05:15 AM
amiram's Avatar
Default prop shaft
As far as I know the prop shaft sold as a complete unit.
Old 05-01-2014, 06:06 AM
jamesm0913's Avatar
AudiQC - Contact Scotty at Advance Automotion in TX and he will fix you up with a better one piece driveshaft with all new joints and boots. If the center support bearing on my A6's prop shaft ever goes out I will be replacing it with a one piece unit for ease of DIY installation.
Old 05-04-2014, 06:23 AM
AudiQC's Avatar
Hi! allroaders....
I have solve my problem...I bought a used prop shaft and intalled it. Everything is very good and no more shaking and clinckings.
Thanks for the comments and suggestions.
Old 05-05-2014, 05:50 AM
sanadrustom's Avatar
I know the problem was solved and from what I'm reading sounds like its something I'm experiencing, it shakes when I'm on the gas but the minute I lift off the shaking goes away, is this something I need to replace the prop shaft? or could it be a bad plug or injector shake? it just feels odd that it came out of no where this past weekend. it vibrates more violently when going on an uphill which makes me think its plugs/injector related but I have no codes
thanks
Old 05-05-2014, 07:50 AM
what i am wondering to be exact after several reading on the internet is, does the propeller shaft move while the car is rolling? ie if its in neutral or in gear but just rolling down the hill lets say? cause it doesn't vibrate at all when my foot is off the gas but still in gear
thanks
Quick Reply: Central driveshaft CV joints
